NetApp Knowledge Base
system node restore-backup fails due to "scp /partner/etc/varfs.tgz root.../var/home/root/failed with error 1. " error
554
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS2620
  • FAS2720
  • FAS2750
  • ONTAP 9.1P9
  • ONTAP 9.7
Issue
  • The impaired node has been taken over by partner node.
  • Could not restore backup configuration from partner node when attempting to restore backup configuration from partner.
  • The following error occurs when executing the restore_backup from the partner node.
Example:
Cluster::*> system node restore-backup -node local -target-address <IP>
Start Restore Backup
mount_partner...success.
scp /partner/etc/varfs.tgz root@<target_IP>:
New to NetApp?
