NetApp Knowledge Base
"Takeover is not possible: Local node missing partner disks" on a node in HA
3,163
Visibility:
Votes:
3
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • High availability (HA)
Issue
  • ONTAP reports takeover not possible:
::>Storage failover show
                              Takeover
Node           Partner        Possible State Description
Node B         Node A         true     Connected to Node A
Node A         Node B         false    Connected to Node B, Takeover is not
                                       disks
  • Disk is failed with Failed-Unsupported status from node A.
::>node run -node <node A> sysconfig -v
10.20: NETAPP   X376_HLBRE08TA07 NA01   0.0GB 0B/sect (Failed-Unsupported)
  • Node B shows the effected disk as Failed
::>node run -node <node B> sysconfig -v
10.20: NETAPP   X376_HLBRE08TA07 NA01 7486.1GB 520B/sect (<serial of disk>) (Failed)
  • The effected disk is moved to maintenance/testing by the owner node and the HA partner is reporting missing partner disks.
  • Only the partner node might report the disk as "Not available" in sysconfig -a
21.22: 0.0GB 0B/sect (Not available.)
New to NetApp?
