NetApp Knowledge Base
"(CHASSIS POWER DEGRADED: Power Supply Status Critical: PSU1, PSU2.) ERROR" AutoSupport message occurs
4,012
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS2620
  • FAS2720
  • FAS2750
  • FAS8200
  • AFF A300
Issue
  • AutoSupport is triggered that the chassis power supply are degraded.
HA Group Notification from node-02 (CHASSIS POWER DEGRADED: Power Supply Status Critical: PSU1, PSU2.) ERROR
  • The following messages show in EMS-LOG-FILE.GZ
[node-02: monitor: monitor.globalStatus.critical:EMERGENCY]: Power Supply Status Critical: PSU1, PSU2.
[node-02: power_low_monitor: monitor.chassisPowerSupplies.ok:info]: Chassis power supplies OK
[node-02: monitor: monitor.globalStatus.ok:info]: The system's global status is normal
New to NetApp?
