"system service-event show" shows "Uncorrectable DRAM ECC" as DIMM state after replacing DIMM
Applies to
- FAS2750
- ONTAP9.4P3
Issue
- The amber system attention LED is illuminated.
- After replacing the DIMM,"
" as DIMM state.
Example:
BMC *> system service-event show
ID FRU Description Fault Reason
1 DIMM in slot 2 in Controller A Uncorrectable DRAM ECC
2 DIMM in slot 2 in Controller A DIMM error recorded in SRAM
