NetApp Knowledge Base
"system node service-processor" shows degraded status after SP reboot
855
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS8040
  • FAS2620
  • Data ONTAP 9
  • Data ONTAP 8
Issue
  • After rebooting the Service Processor (SP), the SP changes to degraded status.
Cluster::*> system node service-processor reboot-sp -node *
Note: If your console connection is through the SP, it will be disconnected.
      Do you want to reboot the SP ? {y|n}: y
2 entries were acted on.
Cluster::*>
    autosupport image       network     reboot-sp   show        snmp
Cluster::*> system node service-processor show
                               IP           Firmware
Node          Type Status      Configured   Version   IP Address
node-1  SP   rebooting   false        3.0.2     -
node-2  SP   rebooting   false        3.0.2     -
                               IP           Firmware
node-1  SP   online      false        3.0.2     -
                               IP           Firmware
node-2  SP   unknown     false        3.0.2     -
                               IP           Firmware
node-2  SP   degraded    true         3.0.2     0.0.0.0
Cluster::> sp   ervice-p r processor show
  (system node service-processor show)
                               IP           Firmware
node-2  SP   offline     true         3.0.2     0.0.0.0
  • "node-1" starts takeover because "node-2's SP goes offline.
Cluster::> Feb 20 09:53:59 [node-2:monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (SP IPMI Dead
Waiting for PIDS: /usr/sbin/ypbind 729.
Waiting for PIDS:  695.
Terminated
Uptime: 28d13h49m5s
System powering down...
System halting...
BIOS version: 9.3
Portions Copyright (c) 2011-2014 NetApp. All Rights Reserved
Waiting for SP ...
SP failure. Resetting SP from primary FW. This can take a few minutes
Waiting for SP ...
SP failure. Resetting SP from backup FW. This can take a few minutes
Waiting for SP ...
Failed to recover SP
IPMI PCI Slot Control failed.
IPMI:Get controller FRU inventory:failed
Phoenix SecureCore Tiano(TM)
Copyright 1985-2021 Phoenix Technologies Ltd.
All Rights Reserved
Build Date: 12/02/2014
*                    9.3                     *
*           PHOENIX SC-T 2009-2021           *
CPU = 1 Processor(s) Detected, Cores per Processor = 8
Intel(R) Xeon(R) CPU E5-2658 @ 2.10GHz
32768 MB System RAM Installed
256 KB L2 Cache
System BIOS shadowed
Video BIOS shadowed
USB Device: MICRON eUSB DISK
Boot Loader version 5.3
Copyright (C) 2000-2003 Broadcom Corporation.
Portions Copyright (C) 2002-2014 NetApp, Inc. All Rights Reserved.
BIOS POST Failure(s) detected: SP IPMI failure. Abort AUTOBOOT
  • Unplugging and re-plugging "node-2" cannot clear the error.
LOADER-B> BIOS version: 9.3
Waiting for SP ...
Waiting for SP ...
Waiting for SP ...
All Rights Reserved
*                    9.3                     *
256 KB L2 Cache
Video BIOS shadowed
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
