"sysconfig -r" doesn't display replaced disk after disk replacement in ADP configuration
Applies to
- Advanced Disk Partitioning (ADP)
- ONTAP 9
- AFF and FAS
Issue
- After replacing the disk in the ADP environment, "
sysconfig -r
" doesn't display the replaced disk. - "
sysconfig -a
" shows the replaced disk.
Before replacement:
00.2 : NETAPP X343_SSKBE1T8A10 NA02 1713.5GB 520B/sect (WXXXXXG5)
00.3 : NETAPP X343_SSKBE1T8A10 NA02 1713.5GB 520B/sect (WXXXXXRF) (Failed)
00.4 : NETAPP X343_SSKBE1T8A10 NA02 1713.5GB 520B/sect (WXXXXXET)
After replacement:
00.3 : NETAPP X343_SSKBE1T8A10 NA02 1713.5GB 520B/sect (WXXXXXBE)
- In
storage disk show -partition-
ownership
outputs, Root and Data are blank, anddisk show -n
isNot Owned
status.
::*> storage disk show -partition-ownership
2.0.3 Container node-a node-a 538164682 538164682
Root - - - -
Data - - - - - - -
::*> disk show -n
DISK OWNER POOL SERIAL NUMBER HOME DR HOME
0b.00.3P1 Not Owned NONE WBXXXXXXXX001
0b.00.3P2 Not Owned NONE WBXXXXXXXX002
