Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
"sysconfig -a" shows "Failed" as Flash Cache State
786
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS3220
  • Data ONTAP 8
Issue
  • "sysconfig -a" shows "Failed" as Flash Cache State.
Example:
slot 2: Flash Cache 2 (512 GB)
State: Failed
Model Name: X1973A-R6
Serial Number: 9458198419
Part Number: 111-00902
Board Revision: D0
  • EMS log reports "iomem.card.fail.internal:critical" and "fmm.domain.card.failure:error".
Example:
[?] Sun Feb 23 20:46:52 JST [node_name: iomem.card.fail.internal:critical]: Caching module (model name X1973A-R6, serial number 9458198419, part number 111-00902) in slot 2 has experienced a fatal internal error (0x4007) and is being taken offline.
[?] Sun Feb 23 20:46:52 JST [node_name: fmm_main: fmm.domain.card.failure:error]: Flash Cache in slot 2 (model name X1973A-R6, serial number 9458198419, part number 111-00902): Flash device failed and needs to be updated or repaired or replaced.
New to NetApp?
Scan to view the article on your device
