Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
"disk replace" fails in ONTAP with error message: "Disk X is not of appropriate size"
1,365
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
core
Last Updated:
Applies To
  • ONTAP 9.6 or earlier running Advanced Disk Partition (ADP)
  • FAS2552
  • FAS2554
Issue
  • The following command fails on a partitioned disk right-sized into a smaller aggregate with a whole disk of appropriate size:
::*> disk replace -disk VMw-1.31 -action start -replacement VMw-1.28
Error: command failed: Disk VMw-1.28 is not of appropriate size.
  • The system should partition the new disk but fails with the error below seen in the EMS:
[cluster-01: mgwd: raid.disk.replace.job.failed:error]: Failed to replace
disk 1.20.0 with disk 1.10.11.
                Reason: Reserve: Unable to reserve disks on source node cluster-01.
New to NetApp?
Scan to view the article on your device
