NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
"Waiting for cluster applications to come online on the local node" displays after takeover and cannot give back
2,379
Visibility:
Votes:
2
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS2650
  • ONTAP 9
  • Service Processor (SP)
Issue
  • After takeover occurs on the system, the message "Waiting for cluster applications to come online on the local node." is displayed and cannot give back.
Example:
::> storage failover show
              Takeover
Node           Partner        Possible State Description
fas2650-a               fas2650-b   true     Connected to fas2650-b
fas2650-b               fas2650-a   true     Connected to fas2650-a.  Waiting for cluster applications to come online on the local node.
2 entries were displayed.
manage::> set diag
manage::*> cluster kernel-service show
Master            Cluster           Quorum Availability  Operational
Node              Node              Status        Status        Status
fas2650-a   fas2650-a   in-quorum     true operational
                      fas2650-b   out-of-quorum false         unknown
fas2650-b   fas2650-a out-of-quorum false         operational
                      fas2650-b   out-of-quorum true          operational
4 entries were displayed.
ura-fas2650-manage::*> cluster kernel-service node show
                 Is     Cluster
Node             Master Node             Status        Status Status
fas2650-a  true   fas2650-a in-quorum     true         operational
fas2650-b  true   fas2650-a  out-of-quorum false        operational
manage::> storage failover giveback -ofnode fas2650-b -override-vetoes true
Warning: Initiating a giveback with vetoes overridden will result in giveback
        proceeding even if the node detects outstanding issues that would make
         a giveback dangerous or disruptive. Do you want to continue?
          {y|n}: y
Error: command failed: Failed to initiate giveback. Reason: A giveback is
       already in progress.
  • EMS log appears following "bsdsocket" errors and "SPLinkDownAlert" message.
Example:
  [?] Fri Jul 10 18:34:40 JST [fas2650-a: kernel: bsdsocket.queueLimit.reached:error]: Number of connection requests for the socket bound to port 935 having the IP address * has reached the limit of 1536 connections. The socket uses TCP protocol. This event has occurred 62 times since the last warning.
  [?] Fri Jul 10 18:35:16 JST [fas2650-a: dsa_vmm: hamsg.noSend:debug]: params: {'req_op': '6', 'remoteID': 'bb7f5031722311e7ab45a7880059a5e9', 'status': '1', 'scope_err': '0', 'scope': '16'}
  [?] Fri Jul 10 18:40:00 JST [fas2650-a: kernel: bsdsocket.queueLimit.reached:error]: Number of connection requests for the socket bound to port 935 having the IP address * has reached the limit of 1536 co
nnections. The socket uses TCP protocol. This event has occurred 49 times since the last warning.
  [?] Fri Jul 10 18:40:41 JST [fas2650-a: dsa_vmm: hamsg.noSend:debug]: params: {'req_op': '6', 'remoteID': 'bb7f5031722311e7ab45a7880059a5e9', 'status': '1', 'scope_err': '0', 'scope': '16'}
  [?] Fri Jul 10 18:45:13 JST [fas2650-a: spmd: spm.servprocd.process.exit:alert]: Service processor daemon (servprocd) with ID 4174 exited as a result of normal exit (1). This server will attempt to restart.
  [?] Fri Jul 10 18:45:15 JST [fas2650-a: servprocd: mdb.recovery.successful:debug]: params: {'name': 'servprocd'}
  [?] Fri Jul 10 18:46:06 JST [fas2650-a: dsa_vmm: hamsg.noSend:debug]: params: {'req_op': '6', 'remoteID': 'bb7f5031722311e7ab45a7880059a5e9', 'status': '1', 'scope_err': '0', 'scope': '16'}
  [?] Fri Jul 10 18:50:19 JST [fas2650-a: nphmd: hm.alert.cleared:info]: params: {'alert_id': 'SPLinkDownAlert', 'alerting_resource': 'SP Config', 'detailed_info': 'Alert Id = SPLinkDownAlert , Alerting Resource = SP Config', 'monitor': 'controller'}
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
