NetApp Knowledge Base
Call home for SHELF_FAULT
414
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • FAS25XX
  • Error is reported on internal storage
Issue
  • The system reports the following error in EMS-LOG-FILE.GZ.
[?] Tue Mar 23 04:37:00 JST [cluster-01: dsa_worker3: ses.status.ACPError:critical]: DS2126 (S/N SHJSGXXXXXXXXXX) shelf 0 on channel 0a ACP Processor error for SAS shelf ACP processor 1: critical status ; Alternate Control Path hardware failed This module is on the rear of the shelf at the top left, on shelf module A.
[?] Tue Mar 23 04:37:00 JST [cluster-01: monitor: monitor.globalStatus.critical:critical]: Disk shelf fault.
[?] Tue Mar 23 04:37:09 JST [cluster-01: statd: monitor.shelf.fault:critical]: Fault reported on disk storage shelf attached to channel 0a. Check fans, power supplies, disks, and temperature sensors.
[?] Tue Mar 23 04:37:09 JST [cluster-01: statd: callhome.shlf.fault:error]: Call home for SHELF_FAULT
  • Alternate Control Path (ACP) is in FAIL status on STORAGE-FAULT output when the error occurs.
Enclosure Status: critical
Channel: 0a
Shelf: 0
Shelf Type: DS2126
Product Serial Number: SHJSGXXXXXXXXXX
Module Type: IOM6E
Vendor Unique Element 85-IOM6E: (ACP)
Element Status Status Bytes Status Descriptions
1 [IOM6E A] : CRITICAL 02,00,00,40 FAIL
2 [IOM6E B] : OK 01,00,00,00
  • The following records can be found from ENVIRONMENT.
Channel: 0a
Shelf: 0
SES device path: local access: 0a.00.99
Module type: IOM6E; monitoring is active
Shelf status: critical condition
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
  • Was this article helpful?
