NetApp Knowledge Base
"Quad Port 12G SAS" test fails in diagnostic test
417
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS8300
  • ONTAP 9
  • System-Level HW Diagnostics 04.03.04
Issue
  • Running the test in three connection patterns following.
    • Shelf and FAS8300 are connected by dual-path, and an appropriate MiniSAS is connected to the open SAS port (Onboard, HBA)
    • Connect to adjacent ports without connecting to the shelf (Onboard, HBA)
    • Quad path connection between shelf and FAS8300 (Onboard only)
  • But all got errors in "h. Onboard: Quad Port 12G SAS Test" and "l. HBA: Quad Port 12G SAS Test".
Example:
Copyright (c) 2019 NetApp Inc. All rights reserved.
FAS8300 System-Level HW Diagnostics 04.03.04
#### System        PN: 111-04200                    ####
#### System        SN: 041951001286                 ####
#### Controller-A  PN: 111-04198                    ####
#### Controller-A  SN: 042008000113                 ####
1) Scan System
2) Test System (must scan system, first)
3) Test Memory (must scan system, first)
4) Stress-Test System (must scan system, first)
5) Show VPD Information
6) Show FW Revision
7) Show MAC Address
8) Show Logs
9) Reboot (BMC Power Cycle) Controller to LOADER
Select a number 1-9 to execute the respective command: 2
+--------------------------------Test System-----------------------------------+
| Select one or more items to test using the SPACE bar to toggle the option.   |
| Use Arrow keys to move up/down to select invidiual test. Use Arrow keys      |
| left/right to select Test Control. Press [Enter] to execut.                  |
| |[ ] a. CPU Test                              (Register read test)         | |
| |[ ] b. TPM Test                              (Self-test)                  | |
| |[ ] c. Ethernet I210 Test                    (Internal loopback test)     | |
| |[ ] d. BMC Test                              (Self-test/Sensor status chec| |
| |[ ] e. PSU Test                              (Sensor status check)        | |
| |[ ] f. PCH-I2C Test                          (Device read test)           | |
| |[ ] g. Fan Test                              (Fan speed control test)     | |
| |[ ] h. Onboard: Quad Port 12G SAS Test       (External loopback test)     | |
| |[ ] i. Onboard: Dual Port 25GbE RoCE NIC Test(BIST/External loopback test)| |
| |[ ] j. Onboard: Dual Port 100GbE RoCE NIC Tes(BIST/External loopback test)| |
| |[ ] k. Mezz: Quad Port 25GbE RoCE NIC Test   (BIST/External loopback test)| |
| |[ ] l. HBA: Quad Port 12G SAS Test           (External loopback test)     | |
<   OK   ><Test all>< Cancel >a(Register read test)
b(Self-test)b(Self-test)
c(Internal loopback test)c(Internal loopback test)
d(Self-test/Sensor status checd(Self-test/Sensor status chec
e(Sensor status check)e(Sensor status check)
f(Device read test)f(Device read test)
g(Fan speed control test)g(Fan speed control test)
h(External loopback test)*h(External loopback test)
i(BIST/External loopback test)i(BIST/External loopback test)
j(BIST/External loopback test)j(BIST/External loopback test)
k(BIST/External loopback test)k(BIST/External loopback test)
l(External loopback test)*1
+------------------Configure Test Loop---------------------+
| Fill in the number of test loops. The acceptable input   |
| value ranges from 0 to 99. A 0 means an infinite loop.   |
| If input value greater then 99, it will be set to 99.    |
| You can use BACKSPACE to correct errors and use ARROW    |
| keys left/right to select Test Control. Use Tab or Arrow |
| keys up/down to move between loop count and Test         |
| Control. Press [Enter] to execute.                       |
|               <  OK  >        <Cancel>                   |+
+---------------Test_Options-----------------+
| Select one item to test using the SPACE    |
| bar to toggle the option. Use Arrow keys   |
| to move up/down to select invidiual test.  |
| Use Arrow keys left/right to select Test   |
| Control. Press [Enter] to execute          |
| |       (*) a. Stop on error             | |
| |       ( ) b. Continue on error         | |
<  OK  ><Cancel>ab*
System Test Start: 2020-06-30 07:42:27
======================== LOOP  1 ===========================
Onboard: Quad Port 12G SAS:SASBB0 Test:
Test Cmd: sas0Stress.sh 1
[2020/06/30 07:42:27] ERROR : SAS ramdisk device lost
[2020/06/30 07:42:27] Expect 8 SAS ramdisk to stress but only found 0 SAS ramdisk
HBA: Quad Port 12G SAS:SASH0 Test:
Test Start: 2020-06-30 07:42:58
Test Cmd: sasHICStress.sh 1
[2020/06/30 07:42:58] ERROR : SAS ramdisk device lost
[2020/06/30 07:42:58] Expect 8 SAS ramdisk to stress but only found 0 SAS ramdisk
System Test Summary:
     Onboard: Quad Port 12G SAS         : FAILED
     HBA: Quad Port 12G SAS             : FAILED
System Test Stop: 2020-06-30 07:43:28
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
