NetApp Knowledge Base
"Multi Disk Panic" (MDP) of takeover node during motherboard replacement
115
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • All Cluster-Mode ONTAP (CDOT) versions and platforms that use partitioned disks.
Issue
  • During a FAS/AFF motherboard replacement, if original motherboard is re-installed before disk reassignment is done (which automatically occurs during giveback), P1 partitions can go missing and cause takeover node to Multi-Disk Panic.
New to NetApp?
Scan to view the article on your device
