"Entering FM state:5 " after boot device replacement due to skipping the file system restore
Applies to
- ONTAP 9
- AFF-A250
- FAS500F
Issue
- After a boot device replacement node unable to be recovered
- While booting node is stuck with the following prompt:
Waiting for giveback...(Press Ctrl-C to abort wait)Entering FM state:5 because mbFound:0 local in headswap:0
- Unable to perform giveback with following state on partner node:
Takeover
Node Partner Possible State Description
cluster1-01 cluster1-02 true Connected to cluster1-02
cluster1-02 cluster1-01 true Kernel loaded
2 entries were displayed.
