"CPU0 Temp Margin" status shows "init_failed" in Environment Log
Applies to
- FAS2650
- FAS2620
- AFF A200
- ONTAP 9.1P7
- ONTAP 9.3
- Service Processor(SP)5.7
Issue
As the following Environment log, "CPU0 Temp Margin
" and system is running normally.
Example:
Internal Shelf PRESENT
CPU0 Temp Margin init_failed -- C -- -- 0 C -1 C ★
CPU0 Core Temp normal 47 C 0 C 5 C 90 C 100 C
PCM_Inlet_Temp normal 33 C 0 C 5 C 67 C 72 C
