NetApp Knowledge Base
What is Watchdog Timer?
2,138
Visibility:
Votes:
1
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
  E-Series
Answer
Watchdog timer
  • A Watchdog timer is a software timer used to detect and recover from deadlock conditions.
  • When a Watchdog timer triggers it interrupts the controller processor by initiating a controller reset.
Placating or resetting the watchdog device
  • The interrupt service routine in the firmware must respond with an action to placate, or reset, the watchdog hardware within a short period of time.
  • If not placated, the watchdog timer will force a hard reset (similar to sysReboot) of the controller.
  • Upon reset, the firmware reports that the controller had been reset by the watchdog timer with the message:
WARNING: Restart by watchdog time out.
Fibre Channel
  • The watchdog timer is enabled for Fibre Channel as there is no equivalent of a scsi-bus-reset.
  • The watchdog timer will reset the controller if there is no fibre channel interrupt serviced for about 5-10 seconds.
  • The array controller generates its own interrupts to cover timers when the host is inactive.
Benefits of a watchdog timer
  • A watchdog timer protects the system from software hangs.
  • It provides a means for errors to be detected and resolved automatically.
  • When watchdog timer ticks down to 0, a system reset is triggered.
  • Watchdog timers allow an automated means of recovering in the event the software becomes hung, so administrator intervention is not required.
Additional Information
Add your text here.
