NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
What is Watchdog Timer?
1,074
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
  E-Series
Answer
Watchdog timer
  • A Watchdog timer is a software timer used to detect and recover from deadlock conditions.
  • When a Watchdog timer triggers it interrupts the controller processor by initiating a controller reset.
Placating or resetting the watchdog device
  • The interrupt service routine in the firmware must respond with an action to placate, or reset, the watchdog hardware within a short period of time.
  • If not placated, the watchdog timer will force a hard reset (similar to sysReboot) of the controller.
  • Upon reset, the firmware reports that the controller had been reset by the watchdog timer with the message:
WARNING: Restart by watchdog time out.
Fibre Channel
  • The watchdog timer is enabled for Fibre Channel as there is no equivalent of a scsi-bus-reset.
  • The watchdog timer will reset the controller if there is no fibre channel interrupt serviced for about 5-10 seconds.
  • The array controller generates its own interrupts to cover timers when the host is inactive.
Benefits of a watchdog timer
  • A watchdog timer protects the system from software hangs.
  • It provides a means for errors to be detected and resolved automatically.
  • When watchdog timer ticks down to 0, a system reset is triggered.
  • Watchdog timers allow an automated means of recovering in the event the software becomes hung, so administrator intervention is not required.
Additional Information
Add your text here.
Scan to view the article on your device
