We are redesigning the NetApp Knowledge Base site to make it easier to use and navigate. The new and improved site will be available the first week of October. Check out our video or read this KB article to know more about changes you’ll see on the site.
What are the possible host side connection topologies for E-Series systems?
199
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
E-Series systems
Answer
Topology Description
Point-to-Point:
The controller and host bus adapter (HBA) host port are directly connected as Nports (non-loop).
Arbitrated Loop:
The controller port is connected to a switch port using a Fibre Channel arbitrated loop. The HBA host port might be on the local loop or connected to the switch. Devices on the loop and storage arrays attached to the switch can communicate with each other.
Arbitrated Loop Private:
The controller port and HBA host port are connected by a Fibre Channel arbitrated loop.
Fabric Attach:
The controller port is connected as an N-port to the fabric (switch) port. The HBA host port is connected elsewhere in the fabric. The switch facilitates communication between the controller port, and the HBA host port.
Additional Information
additionalInformation_text
