NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
NetApp Knowledge Base
Unable to reclaim space from a thin provision volume
1,023
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
E-Series Controller Firmware
Answer
When trying to reclaim deleted blocks or space from E-Series thin provisioned volume, space is not reclaimed and the host SCSI UNMAP operation returns with an error.
SCSI UNMAP was first introduced in E-Series controller firmware starting 8.25.05, which means deleted blocks will not be reclaimed on a volume that was created prior to this release. Once the controller firmware level support this feature, SCSI UNMAP should be enabled on each thin-provisioned volume created prior to 8.25.05. See the following links to enable this feature according to the host OS:
  • FA24: What are Windows host operating system considerations when using SCSI UNMAP with E-Series thin volumes?
  • FA25: What are VMware considerations when using SCSI UNMAP with E-Series thin volumes?
  • FA26: What are Linux host operating system considerations when using SCSI UNMAP with E-Series thin volumes?
Some platforms cannot be upgraded beyond 8.20 and therefore SCSI UNMAP is not supported on these platforms. From customer product communication  CPC-1705-03:
"SANtricity OS 8.20 is at the end of engineering support as of May 1, 2017. The E2600, E5400, and EF540 systems cannot be upgraded beyond SANtricity OS 8.20."
Scan to view the article on your device
