Temperature sensor status is UNKNOWN after upgraded the controller firmware
Applies to
E-series
Issue
- Temperature sensor status is UNKNOWN after upgraded the controller firmware.
Temperature sensor status: UNKNOWN
- The
RECOVERY-GURU-PROCEDURES
showsFailure Entry: MAX_TEMP_EXCEEDED-Recovery Failure Type Code: 8
Storage array: NetappE
Component reporting problem: Thermal sensor
Status: UNKNOWN
Component requiring service: Temperature sensor
Tray: Controller/Drive tray 99
- By the MEL (
MAJOR-EVENT-LOG)
shows the problem that occurred on the affected controller.
A:2020/4/28 下午 04:54:04 (08:54:04) 9658 281c Maximum temperature exceeded - Tray 99 <--CRITICAL
A:2020/4/28 下午 04:54:04 (08:54:04) 9657 281c Maximum temperature exceeded - Tray 99 <--CRITICAL
A:2020/4/28 下午 04:54:04 (08:54:04) 9656 3101 Asynchronous event notification (AEN) posted for recently logged event - Tray 99, Slot A
----> Sense 6/3f/c6 = Unit Attention - Temperature sensor failed
----> FRU group: Subsystem; Tray ID: 99, Type : Temp Sensor, State: Failed
