NetApp E-Series Battery charger in PowrOut state
Applies to
NetApp E-Series and EF-Series
Issue
Battery charging state shows PowrOut in bidshow 255
Date Time State Cmd MfgSts B_Mode Temp A_Volt A_Crnt MaxErr RelSOC RemCap FulCap C_Crnt C_Volt BatSts
06/28/2020 05:58:06 PowrOut DISABAT 0x01F8 0xE001 26 7782 0 1 82 1027 1255 1000 7960 0x00C0
06/28/2020 05:58:21 PowrOut NONE 0x01F8 0xE001 26 7783 0 1 82 1027 1255 1000 7960 0x00C0
06/28/2020 05:58:36 PowrOut ENABAT 0x01F8 0xE001 26 7783 0 1 82 1027 1255 1000 7960 0x00C0
06/28/2020 05:58:47 PowrOut NONE 0x01F8 0xE001 26 7783 0 1 82 1027 1255 1000 7960 0x00C0
Timer is seen inside the same output.
Bid Timers Slot Type State Interval Remaining
Timer[0]: 0 Fault Reset 0:00:00
Timer[1]: 0 Missing Reset 0:00:00
Timer[2]: 0 PowerUp Reset 0:00:00
Timer[3]: 0 Charging Reset 0:00:00
Timer[4]: 0 Learning Reset 0:00:00
Timer[5]: 0 LogTemp Active 0:06:00 0:03:33
Timer[6]: 0 CmdTimer Reset 0:00:00
Timer[7]: 0 SealTimer Reset 0:00:00
Timer[8]: 0 PowerOut Active 24:00:00 23:45:50
Timer[9]: 0 Invalid Reset 0:00:00
