NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
NetApp Knowledge Base
How to determine if write cache is enabled on E-Series
1,106
Visibility:
Votes:
0
Category:
e-series-santricity-os-controller-software
Specialty:
esg
Last Updated:
Applies to
  • E-Series Controller Firmware 7.xx
  • E-Series Controller Firmware 8.xx
There are a few methods for checking if Cache is enabled; the most simple are as follows:
Method 1: STORAGE-ARRAY-PROFILE
Cache settings are reported on a per-volume basis and can be found in the 'STORAGE-ARRAY-PROFILE' file of an E-Series support collection, under the 'Details' portion of the 'Standard Volumes' section.
Potential States:
Write cache:    Enabled
Write cache:    Disabled
Write cache:    Enabled    (currently suspended) <- Indicates controller suspended cache for some reason. Will need to be investigated.
See the attached sample STORAGE-ARRAY-PROFILE.
Method 2: STATE-CAPTURE-DATA
Cache settings can also be found in the 'STATE-CAPTURE-DATA', in the 'ccmShowState' under 'CacheDeviceFlags':
Potential States:
RCE = Read Cache Enabled
RCA = Read Cache Active
RCD = Read Cache Disabled
RCD = Read Cache Inactive
WCE = Write Cache Enabled
WCA = Write Cache Active
WCD = Write Cache Disabled
WCI = Write Cache Inactive
CME = Cache Mirroring Enabled
CMA = Cache Mirroring Active
CMD = Cache Mirroring Disabled
CMI = Cache Mirroring Inactive
WC_INTERNALLY_DISABLED  <- Indicates controller suspended cache for some reason. Will need to be investigated.
CM_INTERNALLY_DISABLED  <- Indicates controller suspended cache for some reason. Will need to be investigated.
See the attached sample STATE-CAPTURE-DATA.
New to NetApp?
Scan to view the article on your device
