Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
E-Series Drive failed initialization/reconstruction failure - AutoSupport Message
96
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
NetApp E-Series
Event Summary
SANtricity reports a failed initialization/reconstruction failure event. This results in a failed drive in most cases.
Validate
  1. Login to SANtricity Storage Manager or SANtricity System Manager
  2. Confirm SANtricity reports one of more of the following error messages in the Recovery GURU:
    • FAILED_DRIVE-Recovery Failure Type Code: 23 Failed Drive
    • FAILED_DRIVE-Recovery Failure Type Code: 23 Failed Physical Disk - Unassigned or Standby Hot Spare
    • DISK_POOL_DRIVE_FAILURE-Recovery Failure Type Code: 443 Failed Disk Pool Drive
  3. Confirm from the Hardware tab that the drive shows as failed
Resolution
  • Contact NetApp Technical Support as this will require a drive replacement
  • If AutoSupport is enabled, this event should have already created a technical support case
Additional Information
Add your text here.
Scan to view the article on your device
