NetApp Knowledge Base
E-Series Controller tray component removed - AutoSupport Message
47
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
NetApp E-Series
Event Summary
SANtricity reports one or multiple events for a controller tray component being removed, such as a controller.
Validate
  1. Login to SANtricity Storage Manager or SANtricity System Manager
  2. Go to the Hardware tab
  3. Confirm the status of the component reporting as removed
Resolution
  1. Verify if there is any maintenance being performed.
  2. Verify the status of the component that is being reported as removed. Try reseating the component.
  3. Verify the Event Logs from Support > Event Logs and confirm if any other events may have caused the errors to be reported.
  4. Contact NetApp Technical Support if further troubleshooting is required.
Scan to view the article on your device
