E-Series A drawer in the tray has become degraded - AutoSupport Message
Applies to
NetApp E-Series
Event Summary
- An AutoSupport messages is generated with title:
E-Series Notification from E2860 (A drawer in the tray has become degraded) CRITICAL
- An associated case is generated with symptom:
EHWENC:E-Series Notification from E2860 (A drawer in the tray has become degraded) CRITICAL
Validate
- Login to SANtricity Storage Manager or SANtricity System Manager
- Confirm SANtricity reports one of more of the following error messages in the Recovery GURU:
DRAWER_DEGRADED-Recovery Failure Type Code: 393
- Confirm if the Major Event Log (MEL)
A:12/22/21 12:07:56 PM (11:07:56) 401865 285f A drawer in the tray has become degraded - Tray 1, Drawer 3 <--CRITICAL
- Confirm from the Hardware tab that the drawer shows as degraded
- Confirm status of drawer in
Storage array profile
Example:
Drawers Detected: 3
Drawer status: Optimal
Position: 1
Part number: PN 111-03261
Serial number: SN xxxxxxxx
Manufacturer: VN NETAPP
Date of manufacture: 11/1/16
FRU Type: FT SASDRWR
Position: 2
Drawer status: Degraded
Position: 3
Resolution
- Ensure no other hardware issues exist, such as a degraded/failed controller which would cause this event.
- Attempt to reseat the flex cable between the drawer and chassis.
- Contact NetApp Technical Support as this will likely require a drawer replacement
- If AutoSupport is enabled, this event should have already created a technical support case
Additional Information
E-series DRAWER_DEGRADED status changes between Degraded and Optimal
