Does the mixed capacity disk drive can be added to the DDP/Volume Groups
Applies to
- SANtricity Storage Manager 11.60
- E2860
Answer
Yes. the mixed capacity disk drive can be added to the DDP(Dynamic Disk Pool)/Volume Groups.
- The Drives must have the same drive type (HDD or SSD) in DDP/Volume Groups.
- If you must add unassigned drives with a smaller capacity, be aware that the usable capacity of each drive currently in the pool or volume group is reduced. Therefore, the drive capacity is the same across the pool or volume group.
- If you must add unassigned drives with a larger capacity, be aware that the usable capacity of the unassigned drives that you add is reduced so that they match the current capacities of the drives in the pool or volume group.
