NetApp Knowledge Base
Controller rebooted due to ALT NMI panic
359
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
  • E5600
  • E2800
Issue
Major-Event-Log reports Reboot Reason : CMGR: REBOOTALT_CMGR_SET_ALT_TO_FAILED
B:6/25/21 7:54:53 PM (02:54:53) 11236 400f Controller reset by its alternate - Tray 99, Slot A
----> Reboot Reason : VTM: REBOOTALT_VTM_UNTIL_FORCED_TRANSFER_COMPLETION
B:6/25/21 7:54:53 PM (02:54:53) 11235 400c Controller placed offline - Tray 99, Slot A
B:6/25/21 7:54:39 PM (02:54:39) 11233 3700 Core dump has been captured - None
B:6/25/21 7:54:39 PM (02:54:39) 11232 2605 Start-of-day routine completed - Tray 99, Slot B
B:6/25/21 7:53:55 PM (02:53:55) 11224 6107 This controller's alternate is non-functional and is being held in reset - Tray 99, Slot A <--CRITICAL
B:6/25/21 7:53:55 PM (02:53:55) 11223 2829 Controller redundancy lost - Tray 99, Slot B <--CRITICAL
B:6/25/21 7:53:55 PM (02:53:55) 11222 400f Controller reset by its alternate - Tray 99, Slot A
----> Reboot Reason : CMGR: REBOOTALT_CMGR_SET_ALT_TO_FAILED
B:6/25/21 7:53:55 PM (02:53:55) 11221 400c Controller placed offline - Tray 99, Slot A
B:6/25/21 7:49:53 PM (02:49:53) 11207 400f Controller reset by its alternate - Tray 99, Slot A
----> Reboot Reason : DCDM: REBOOT_DCDM_ALT_CORE_DUMP_TIMEOUT
B:6/25/21 7:46:30 PM (02:46:30) 11206 1712 Controller wide port has gone to optimal state - Tray 99, Slot A
----> SAS Port WWN: 50080e54786580bf, Attached SAS Port: 50080e5478764020, 1st Phy: 28, Active Phys: 4/4, Channel: 2, Level: 1, PortType: Connection to local ctlr
B:6/25/21 7:46:30 PM (02:46:30) 11205 1712 Controller wide port has gone to optimal state - Tray 99, Slot B
----> SAS Port WWN: 50080e54787640bf, Attached SAS Port: 50080e5478764000, 1st Phy: 24, Active Phys: 4/4, Channel: 3, Level: 1, PortType: Connection to local ctlr
B:6/25/21 7:46:30 PM (02:46:30) 11204 1712 Controller wide port has gone to optimal state - Tray 99, Slot B
----> SAS Port WWN: 50080e54787640bf, Attached SAS Port: 50080e5478764000, 1st Phy: 24, Active Phys: 4/4, Channel: 4, Level: 1, PortType: Connection to local ctlr
B:6/25/21 7:46:08 PM (02:46:08) 11203 2606 Start-of-day routine begun - Tray 99, Slot B
New to NetApp?
