SQL Server detected a logical consistence-based I/O error: restore pending
Applies to
- E-series storage array
- Windows Host
- SQL Application
Issue
- Volume gets frequent errors while accessing and SQL application encounters errors. This gets fixed automatically and same is repeated frequently.
The Storage Volume looks healthy however NTFS filesystem is reporting errors.
There are no path issues found from storage logs related to the volumes experiencing disconections.
- Check Event viewer logs, the NTFS reports errors on the D drive, perform repair manually.
