NetApp Knowledge Base
Virtual Storage Console 4.x stops working after vCenter 5.5U3b update
202
Visibility:
Votes:
0
Category:
virtual-storage-console-for-vmware-vsphere
Specialty:
virt
Last Updated:
Applies to
  • Clustered Data ONTAP 8
  • FlexPod
  • Clustered Data ONTAP 8.2
  • FAS6220
  • Clustered Data ONTAP 8.1
Issue
A Virtual Storage Console (VSC)/SMVI 4.2.2 backup stops working with the following error:
Backups not listing HTTP 504: Gateway Timeout
Unable to backup systems from within VCenter.
  • Clicking the Backup and recovery Configuration option in the VSC plugin in VCenter displays an unable to connect to virtual storage console error
  • Running smvi backup list and other SMVI commands from the VSC server displays an error, and throws java exceptions about handshake failures and a connection been closed in the logs.
Specific issue (identified using Wireshark):
  • After the TCP three-way handshake, VSC by default sends an SSL client hello handshake proposing SSLv3 (0x0300) to vCenter.
  • vCenter then FIN, ACK the connection immediately, causing VSC to issue a fatal alert handshake failure packet back to vCenter, and the client programs to fail/error out. Forcing the client-initiated connections to negotiate at TLSv1 will resolve the issue.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
