NetApp Knowledge Base
Virtual Storage Console (VSC): datastore provisioning creates indirect mounts when storage is added by SVM
137
Visibility:
Votes:
0
Category:
virtual-storage-console-for-vmware-vsphere
Specialty:
virt
Last Updated:
Applies to
  • Virtual Storage Console (VSC) 7.x
  • Virtual Storage Console (VSC) 9.x
Issue
When provisioning storage in ONTAP it is considered best practice to:
  • Mount the volume to a LIF that is on the same node as the volume
  • Avoid mounting a volume to a LIF that is on a node that is not local to the volume.  This creates an indirect path to the volume and should be avoided
There is a bug encountered in Virtual Storage Console when the SVM is directly attached (using a SVM management LIF) in Virtual Storage Console > Storage Systems:
  • VSC mounts the volume to any available LIFs randomly, regardless of which aggregate (node) is chosen
  • This is considered unexpected behavior
The following example illustrates this behavior when storage is SVM scoped in VSC:
  1. In our example, two aggregates are assigned to the SVM:
AGGR                                         NODE                      IP ADDRESS
aggr1_8a                                     fas2520-rtp-8a            10.61.75.41, 10.61.75.46
aggr1_8b                                     fas2520-rtp-8b            10.61.75.43, 10.61.75.47
  1. There are also two other aggregates present in the environment (but not assigned to the SVM):
aggr0_fas2520_4n_rtp_1_03_0                      fas2520-rtp-9a            10.61.75.44, 10.61.75.48
aggr0_fas2520_4n_rtp_1_04_0                      fas2520-rtp-9b            10.61.75.45, 10.61.75.49
  1. While provisioning a total of six datastores the following behavior is seen:
1. nfs_01 - aggr1_8a selected in VSC, node 8a - volume mounted at 10.61.75.48, node 9a - Indirect
2. nfs_02 - aggr1_8b selected in VSC, node 8b - volume mounted at 10.61.75.49, node 9b - Indirect
3. nfs_03 - aggr1_8a selected in VSC, node 8a - volume mounted at 10.61.75.46, node 8a - Direct
4. nfs_04 - aggr1_8b selected in VSC, node 8b - volume mounted at 10.61.75.47, node 8b - Direct
5. nfs_05 - aggr1_8a selected in VSC, node 8a - volume mounted at 10.61.75.44, node 9a - Indirect
6. nfs_06 - aggr1_8b selected in VSC, node 8b - volume mounted at 10.61.75.48, node 9b - Indirect
  1. Additionally, when navigating to VSC > Storage Systems > svm1 > Related Objects > NAS,  we see that the Data Path Access field is unpopulated:
This behavior is not seen when storage is added to Virtual Storage Console > Storage Systems at the cluster level:
  • With cluster scoped storage, VSC correctly evaluates which LIFs to mount to based on SVM and aggregate selected
  • With cluster scoped storage, VSC follows the best practice of direct paths
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
