Virtual Storage Console (VSC): ESX or ESXI host displays an alert status in VSC
Applies to
- Virtual Storage Console (VSC) 6.x
- Virtual Storage Console (VSC) 7.x
Issue
An ESX or ESXi host displays an alert status in VSC. There are two main places you may see host alerts. The first is the Related Objects tab when you open your cluster or SVM from the Storage Systems menu:
The second is the Host Settings from the VSC main page. In VSC 6.x that can be found under Host Settings Status:
In VSC 7.x that can be found under Host Systems:
