Virtual Storage Console 4.x stops working after vCenter 5.5U3b update
Applies to
- Clustered Data ONTAP 8
- FlexPod
- Clustered Data ONTAP 8.2
- FAS6220
- Clustered Data ONTAP 8.1
Issue
A Virtual Storage Console (VSC)/SMVI 4.2.2 backup stops working with the following error:
Backups not listing HTTP 504: Gateway Timeout
Unable to backup systems from within VCenter.
- Clicking the
Backup and recovery Configuration
option in the VSC plugin in VCenter displays anunable to connect to virtual storage console
error - Running
smvi backup list
and other SMVI commands from the VSC server displays an error, and throws java exceptions about handshake failures and a connection been closed in the logs.
Specific issue (identified using Wireshark):
- After the TCP three-way handshake, VSC by default sends an SSL client hello handshake proposing SSLv3 (0x0300) to vCenter.
- vCenter then FIN, ACK the connection immediately, causing VSC to issue a fatal alert handshake failure packet back to vCenter, and the client programs to fail/error out. Forcing the client-initiated connections to negotiate at TLSv1 will resolve the issue.
