NetApp Knowledgebase
Virtual Storage Console: "Hostname in certificate didn't match" error when using CA signed certs
79
Visibility:
Votes:
0
Category:
virtual-storage-console-for-vmware-vsphere
Specialty:
virt
Last Updated:
Applies to
  • Virtual Storage Console 9.6 (VMware)
Issue
NOTE: This issue does not cover the procedure for replacing Virtual Storage Console's self signed certificate with a CA signed certificate.  The KB that walks through that procedure can be found here.
After replacing Virtual Storage Console's (VSC) self signed certificate with a CA (Certificate Authority) signed certificate, some functionality such as VSC's storage mapping's pane no longer works.  In the logs, errors similar to the following are seen:
02/26/20 EST 13:06:09 (ERROR) [cxf-727180:public-interface:clusterAddBasic-11] An exception was thrown by , hostname in certificate didn't match: <192.168.0.35> != <>
org.springframework.remoting.RemoteAccessException: Could not access HTTP invoker remote service at https://192.168.0.35:8143/remoting/s...&locale=en_US]; nested exception is javax.net.ssl.SSLException: hostname in certificate didn't match: <192.168.0.35> != <>
        at org.springframework.remoting.httpinvoker.HttpInvokerClientInterceptor.convertHttpInvokerAccessException(HttpInvokerClientInterceptor.java:226)
        at org.springframework.remoting.httpinvoker.HttpInvokerClientInterceptor.invoke(HttpInvokerClientInterceptor.java:153)
        at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
        at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:213)
        at com.sun.proxy.$Proxy122.getAllStorageSystems(Unknown Source)
        at com.netapp.vasa.vvol.vsc.VscCallWrapper.getAllStorageSystemsPrivate(VscCallWrapper.java:48)
        at com.netapp.vasa.vvol.vsc.VscCallWrapper.getAllStorageSystems(VscCallWrapper.java:37)
        at com.netapp.vasa.vvol.vsc.VscCallWrapper$$FastClassBySpringCGLIB$$20c3a590.invoke(<generated>)
        at org.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:204)
        at org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.invokeJoinpoint(CglibAopProxy.java:738)
        at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157)
        at org.springframework.aop.aspectj.MethodInvocationProceedingJoinPoint.proceed(MethodInvocationProceedingJoinPoint.java:85)
        at com.netapp.vasa.vvol.ws.LoggingAspect.processMethodCallSimple(LoggingAspect.java:724)
        at com.netapp.vasa.vvol.ws.LoggingAspect.logTimeMethodVscInternal(LoggingAspect.java:672)
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
