Virtual Storage Console
Other Resources
- vSphere shows higher volume usage than ONTAPTue, 26 Mar 2024
- OTV: Unable to upgrade to OTV 9.13P1Mon, 25 Mar 2024
- ONTAP Tools for VMware vSphere: HTTP ERROR 503 Service Unavailable when exporting OTV logsWed, 20 Mar 2024
- OTV fails to resize SMBC protected volumesWed, 20 Mar 2024
- What to check if OTV is unresponsive state?Tue, 19 Mar 2024
- Error occurred while updating storage system and provisioning setting detailsTue, 19 Mar 2024
- ONTAP Tools for VMware vSphere: OTV not reporting Storage Details when in VCF modeMon, 18 Mar 2024
- Uninstalling the NFS plugin for VMware VAAI fails with error "Failed to unmount tarddiskntap"Wed, 13 Mar 2024
- Upgrade from 9.10 to 9.13P1 Build 9816 resulted in Error account validation failureWed, 13 Mar 2024
- ONTAP Tools for VMware vSphere: 9.13P1 upgrade fails with 'grub_disk_native_sectors' not found errorWed, 13 Mar 2024
- ONTAP Tools for VMware vSphere: How to confirm what type of certificates are used by OTVTue, 12 Mar 2024
- Does ONTAP tools boot up when the DNS server is down?Fri, 08 Mar 2024
- Unable to deploy OTV plugin Connect timeout 9.12Thu, 07 Mar 2024
- How to tune memory settings of OTV/VSC for scale and performance 9.12 and aboveWed, 06 Mar 2024
- OTV: Read error during storage discovery using a Discovery privilege userMon, 04 Mar 2024
- What permissions are needed for an ONTAP tools custom vcenter role?Thu, 29 Feb 2024
- ONTAP Tools for VMware vSphere (OTV): Unable to remove old storage systemWed, 28 Feb 2024
- ONTAP Tools for VMware vSphere: Unable to add storage system to OTV after renewing ONTAP CA signed certificatesWed, 28 Feb 2024
- ONTAP Tools for VMware vSphere: How to import a certificate chain into OTV when CA certificates are not used for OTVTue, 27 Feb 2024
- ISCSI Target Configuration for Vmware when using OTVTue, 27 Feb 2024
- ONTAP Tools for VMware vSphere: 9.12 release does not use the correct certificateWed, 27 Mar 2024
- ONTAP Tools for VMware vSphere: Implementing CA signed certificates for 9.12 and newerWed, 27 Mar 2024
- OTV 9.12 The specified Name or IP Address is incorrect when adding storage systemWed, 27 Mar 2024
- How to tune memory settings of OTV/VSC for scale and performance 9.12 and aboveWed, 27 Mar 2024
- Does ONTAP tools boot up when the DNS server is down?Mon, 25 Mar 2024
- Error occurred while updating storage system and provisioning setting detailsWed, 20 Mar 2024
- Is there a way to extend the expiray period of 90 days for Administrator and Derby database passwordMon, 18 Mar 2024
- ONTAP Tools for VMware vSphere: OTV randomly displays privilege exceptionFri, 15 Mar 2024
- ONTAP Tools for VMware vSphere: Datastore provisioning wizard shows incorrect datacenterFri, 15 Mar 2024
- Virtual Storage Console: How to retrieve the JSON file to configure user roles and privilegesFri, 15 Mar 2024
- Unable to deploy OTV Error downloading plugin 9.11Thu, 14 Mar 2024
- Unable to deploy OTV plugin Connect timeout 9.12Thu, 14 Mar 2024
- ONTAP Tools: VSC in-place upgrading failure due to tcpdump package update errorThu, 14 Mar 2024
Highest rated
(rating)- ONTAP tools for VMWare vSphere (VSC) - CVE-2021-44228 Apache Log4j Vulnerability - Workaround
- How to configure VMware vSphere 4.x with Data ONTAP 8.x
- Importing CA-signed certificate in VSC fails for IPv6
- ONTAP Tools for VMware vSphere (OTV): How to Register/Change Password OTV 9.12+ with vCenter
- Virtual Storage Console (VSC) The matching datastore for the specified host could not be found
- OTV: Error 'Node Mgmt LIF IP Address' when adding a storage
- Cannot select thick provision disks when creating or editing VMDKs from vCenter Server
- What is a VAAI primitive and what are its limitations?
- After OTV upgrade Rediscover All - Storage Systems show as 'Unknown'
- ONTAP Tools for VMware vSphere: A primer on how discovery works and can be adjusted
- OTV fails to provision NFS datastore at both ESXi host and cluster level
- Interface for the OTV plugin is not loading when having multiple vCenter servers in linked-mode
- ONTAP Tools (OTV): How to use the kaminoprefs file to specify which IP addresses to use for mounting using VSC Provisioning and Cloning
- VSC: SVM missing from Storage Systems menu after successful cluster discovery
- Error while loading Storage Virtual Machine information for controller ID
Recently updated
(date updated)- ONTAP Tools for VMware vSphere: 9.12 release does not use the correct certificate
Recently added
(date created)- vSphere shows higher volume usage than ONTAP
