Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
Virtual Storage Console: "Hostname in certificate didn't match" error when using CA signed certs
237
Visibility:
Votes:
0
Category:
virtual-storage-console-for-vmware-vsphere
Specialty:
virt
Last Updated:
Applies to
  • Virtual Storage Console 9.6 (VMware)
Issue
NOTE: This issue does not cover the procedure for replacing Virtual Storage Console's self signed certificate with a CA signed certificate.  The KB that walks through that procedure can be found here.
After replacing Virtual Storage Console's (VSC) self signed certificate with a CA (Certificate Authority) signed certificate, some functionality such as VSC's storage mapping's pane no longer works.  In the logs, errors similar to the following are seen:
02/26/20 EST 13:06:09 (ERROR) [cxf-727180:public-interface:clusterAddBasic-11] An exception was thrown by , hostname in certificate didn't match: <192.168.0.35> != <>
org.springframework.remoting.RemoteAccessException: Could not access HTTP invoker remote service at https://192.168.0.35:8143/remoting/s...&locale=en_US]; nested exception is javax.net.ssl.SSLException: hostname in certificate didn't match: <192.168.0.35> != <>
        at org.springframework.remoting.httpinvoker.HttpInvokerClientInterceptor.convertHttpInvokerAccessException(HttpInvokerClientInterceptor.java:226)
        at org.springframework.remoting.httpinvoker.HttpInvokerClientInterceptor.invoke(HttpInvokerClientInterceptor.java:153)
        at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
        at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:213)
        at com.sun.proxy.$Proxy122.getAllStorageSystems(Unknown Source)
        at com.netapp.vasa.vvol.vsc.VscCallWrapper.getAllStorageSystemsPrivate(VscCallWrapper.java:48)
        at com.netapp.vasa.vvol.vsc.VscCallWrapper.getAllStorageSystems(VscCallWrapper.java:37)
        at com.netapp.vasa.vvol.vsc.VscCallWrapper$$FastClassBySpringCGLIB$$20c3a590.invoke(<generated>)
        at org.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:204)
        at org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.invokeJoinpoint(CglibAopProxy.java:738)
        at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157)
        at org.springframework.aop.aspectj.MethodInvocationProceedingJoinPoint.proceed(MethodInvocationProceedingJoinPoint.java:85)
        at com.netapp.vasa.vvol.ws.LoggingAspect.processMethodCallSimple(LoggingAspect.java:724)
        at com.netapp.vasa.vvol.ws.LoggingAspect.logTimeMethodVscInternal(LoggingAspect.java:672)
New to NetApp?
Scan to view the article on your device
