NetApp Knowledge Base
Unable to create VM's inside VVOL if storage password has "@" character
857
Visibility:
Votes:
0
Category:
virtual-storage-console-for-vmware-vsphere
Specialty:
virt
Last Updated:
Applies to
OTV 9.8
Issue
  • VM create operation inside VVOL fails with error.
  • Create Folder, large file copy works within VVOL.
  • Operation fails only when adding a VM inside the VVOL.
  • Traditional dashboard do not show Aggregate space savings
  • vVol dashboard do not show Aggregate space savings
Error reported by VCenter Task and ESX Hostd Logs.
 reason = "Error creating disk Error creating VVol Object. This may be due to insufficient available space on the datastore or the datastore's inability to support the selected provisioning type"-->    msg = "A general system error occurred: Error creating disk Error creating VVol Object. This may be due to insufficient available space on the datastore or the datastore's inability to support the selected provisioning type"--> }
New to NetApp?
Scan to view the article on your device
