NetApp Knowledge Base
Prefix length can not be saved when setting up VSC within IPv6 environment
110
Visibility:
Votes:
0
Category:
virtual-storage-console-for-vmware-vsphere
Specialty:
virt
Last Updated:
Applies to
  • Virtual Storage Console (VSC) 9.6P1, 9.6P2 and 9.7
  • IPv6 environment
Issue
When changing the IPv6 prefix length in Virtual Storage Console's Network Configuration menu, the change isn't saved.  The following procedure does not work:
Example:
  1. Go to network configuration menu and select 2) Change IP address settings
  2. Change the prefix length from default value 128 to 64:
  3. Save all the settings.
  4. Review the network configuration again.  The prefix length shows 128 instead of 64.
New to NetApp?
Scan to view the article on your device
