NetApp Knowledge Base
How to configure VSC to discover storage using SVM credentials
210
Visibility:
Votes:
1
Category:
virtual-storage-console-for-vmware-vsphere
Specialty:
virt
Last Updated:
Applies to
  • Virtual Storage Console 9.x
  • ONTAP 8.x and later
Answer
In order for Virtual Storage Console to discover storage using SVM credentials, the SVM must meet the following conditions:
Then, configure the SVM in VSC:
  • If the storage is already being discovered as a cluster:
    • Select the discovered storage cluster, and then click ACTIONS > Modify.
    • Fill in the SVM login information in the Modify Storage System dialog box.
  • If the storage is not yet discovered by VSC:
    • Add a storage system to VSC by using the VSC home page:
      • Click Storage Systems > Add, or
      • Click Overview > Getting Started, and then click ADD button under Add Storage System.
    • In the Add Storage System dialog box, enter the management IP address and credentials for the SVM.
    • Click OK after you have added all of the required information.
Additional Information
Adding multiple controllers? See Setting default credentials for storage systems.
Scan to view the article on your device
