SMBR failing with "Command Mount-SdSnapshot failed" cause by missing Powershell Module
Applies to
- Single Mailbox Recovery (SMBR)
- SnapCenter (SC)
- SnapCenter Plug-in for Exchange (SCE)
- SnapDrive for Windows (SDW)
Issue
- During recovery when you select Mount/Launch button the GUI will display:
"Command Mount-SdSnapshot failed. Please contact technical support representative"
SnapshotManager.log
might include the one of the following statement:
1.A parameter cannot be found that matches parameter name 'AutopickMountPoint'.Exception stack:
2.ERROR ao - Command execution error: FullyQualifiedErrorId: System.ArgumentExceptionException message: Input path '<LUN_Path>' is not supported :Exception stack:
