NetApp Knowledge Base
Select disks were created successfully but not discovered in ONTAP
128
Visibility:
Votes:
0
Category:
ontap-select
Specialty:
core
Last Updated:
Applies to
  • ONTAP Select
  • ONTAP Select Deploy
  • Disk Add
Issue
  • Storage disk add from Deploy failed with an error.
Storage add failed for node "node_name" in cluster "cluster_name". If the cluster has been reconfigured outside of ONTAP Select Deploy, run a refresh operation on the cluster, and then try the operation again. Reason: StorageAddDisksNotSeenOnONTAP: Disks were created successfully for node "node_name" in cluster "cluster_name", but were not discovered in ONTAP. If the cluster has been reconfigured outside of ONTAP Select Deploy, run a refresh operation on the cluster, and then try the operation again.
  • Cluster Refresh did not resolve the issue.
New to NetApp?
Scan to view the article on your device
