NetApp Knowledge Base
Procedure in case of split brain scenario for OTS
290
Visibility:
Votes:
0
Category:
ontap-select
Specialty:
ontapselect
Last Updated:
Applies to
  • ONTAP Select (OTS)
  • ONTAP multi-node Cluster
  • Split-brain scenario
  • What is the procedure in case of split brain scenario for OTS with 2 node HA-pair + Deploy.
  • In case of failure of Deploy and then one of the nodes, surviving node will change its LIFs to ADMIN UP / OPER DOWN until its partner come back online again.
  • Takeover was not possible since Deploy failed first.
  • In that scenario, cannot recover failed and surviving node remain online, what is the procedure to recover LIFs to OPER UP
New to NetApp?
