Network connectivity checker fails in ONTAP Select Deploy for cluster join
Applies to
ONTAP Select Deploy (Deploy)
ONTAP Select (OTS)
Distributed Resource Scheduler (DRS)
Issue
Running connectivity checker in Deploy fails due to cluster join error message.
Example:
ONTAPClusterCreateJoinOperationFailed: ONTAP cluster create failed during cluster join operation on cluster "mySelectCluster". Reason: Failed to start cluster join on node: 169.254.10.200: Setup failed between nodes node1 and node2 with :Could not retrieve partner SFO information: entry doesn't exist. Resolve the issue, then try the command again.
