Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
Failed to add capacity for ONTAP Select with error NodeVMNotFound
267
Visibility:
Votes:
0
Category:
ontap-select
Specialty:
core
Last Updated:
Applies to
ONTAP Select Deploy 9.4.29
Issue
  • Failed to add capacity for ONTAP Select with error as below:
StorageAddFailed
NodeVMNotFound: Node "ONTAPSelect-01" in cluster "ONTAPSelect" not found on any host. If the cluster has been reconfigured outside of ONTAP Select Deploy, run a refresh operation on the cluster, and then try the operation again.
  • The node is degraded.
  • Ran a cluster refresh, which failed with error unknown, issue persists that the node is degraded and failed to add capacity from the ONTAP Select cluster.
New to NetApp?
Scan to view the article on your device
