Can direct-attached storage (DAS) ONTAP Select and Deploy instances be Vmotioned when upgrading ESX firmware?
Applies to
- ONTAP Select
- ONTAP Deploy
- ESXi
- VMware
Answer
DAS ONTAP Select HA nodes cannot be vmotioned.
- Takeover/Givebacks will need to be completed during the ESXi firmware upgrade.
ONTAP Deploy can be Vmotioned prior to the upgrade.
- It's recommended it be done cold by powering down the Deploy node, Vmotion, then power on. (This is non-disruptive to the HA cluster)
Additional Information
- The upgraded ESX image must have the vendor RAID controller driver installed, so it will need to be downloaded from the ESX vendor. Do not use the vmware image.
- NetApp Interoperability Matrix can be used to verify the ONTAP Select/Deploy versions are supported with the new ESX image version.
- ONTAP Select on VMware
