Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
What is the method to clear or kill a hung rsh or ssh process?
1,145
Visibility:
Votes:
0
Category:
data-ontap-7
Specialty:
7dot
Last Updated:
Applies to
Data Ontap 7 Mode
Answer
RSH
ONTAP-7-mode
Prior to Data ONTAP 7.3.1, the only way to clear a hung rsh process is to reboot the storage system.
For Data ONTAP 7.3.1 and later, the storage administrator can use the rshkill command.
Example:
Use rshstat -a to display the active the rsh sessions:
   filer> rshstat -a
   Session Invocations:         0
   Current Active Sessions:     2
   Active High Sessions:        2
   Maximum Available Sessions:     24
Then, use the rshkill command to clear the process.
  filer> priv set advanced; rshkill 1; priv set
  rshkill: rsh session 1 was closed successfully.
  filer>
Session numbers range from 0 to 23
Clustered ONTAP
RSH is disabled by default- ---RSH is disabled in the pre-defined management firewall policy for clustered ONTAP
To enable rsh in clustered data ontap 8 and ontap 9 run the following command :
cluster::> set advanced; security protocol modify -application rsh -enabled tru
SSH
For SSH related issues contact NetApp Technical Support
Additional Information
Add your text here.
Scan to view the article on your device
