NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
Is it possible to specify the disk that will replace a failed disk drive using the disk fail command?
914
Visibility:
Votes:
0
Category:
data-ontap-7
Specialty:
7dot
Last Updated:
Applies to
  • Data ONTAP 8.2.5 and earlier
  • Data ONTAP operating in 7-Mode
Answer
RFE - Give storage system administrators the ability to configure specific order in which spare disks are selected to rebuild a volume.
No. The disk fail command is used to remove a file system disk that may be logging excessive errors and requires replacement.
For Data ONTAP version earlier than 6.5.2, the storage system does not allow for a pre-defined disk to replace a failed disk drive. The storage system will use the first compatible spare disk that appears in 'sysconfig -r' or 'vol status -r' output.
With Data ONTAP 6.5.2 and after, there is a disk replace command which can be used to replace a file system disk with a more appropriate spare disk:
disk replace start [-f] disk_name spare_disk_name
This command uses Rapid RAID Recovery to copy data from the specified file system disk to the specified spare disk. At the end of that process, roles of disks are reversed. The spare disk will replace the file system disk in the RAID group and the file system disk will become a spare. The -f option can be used to skip the confirmation.
disk replace stop disk_name
This command can be used to abort disk replace, or to prevent it if copying did not start.
Additional Information
additionalInformation_text
Scan to view the article on your device
