Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
How to use lun snap usage -s when deleting busy snapshot copies
467
Visibility:
Votes:
0
Category:
data-ontap-7
Specialty:
7dot
Last Updated:
Applies to
Data ONTAP 8 7-Mode
Data ONTAP 7 and earlier
  • When a snapshot copy is in a busy state, there are backing LUNs (LUN clones) and/or snapshot copies that are using data contained in the snapshot copy. In order to delete the busy snapshot copy, you must first delete the backing LUNs and snapshot copies.
  • You use the "lun snap usage" command to identify these backing LUNs and snapshot copies. However, the "lun snap usage" command output can be lengthy and difficult to read, especially when using SnapDrive, which assigns names that are not always intuitive.
New to NetApp?
Scan to view the article on your device
