NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
NetApp Knowledge Base
How to set up NTP time synchronization in Data ONTAP 7-Mode
4,119
Visibility:
Votes:
0
Category:
data-ontap-7
Specialty:
7dot
Last Updated:
Applies to
Data ONTAP 7 and earlier
This article describes the procedure on how to set up NTP time synchronization in Data ONTAP 7-Mode and to configure SNTP.
To configure SNTP, perform the step below :
  1. Set up SNTP (Simple Network Time Protocol)
Notes:
  • Reminder: you should also set option timed.servers on the partner node or the next takeover might not function correctly. Change the timed.servers option which applies to both members of the cluster in takeover mode. This value must be the same in both cluster members earlier than any takeover or giveback, or that next takeover/giveback might not work correctly.
  • Option timed.servers changed on one cluster node.
New to NetApp?
Scan to view the article on your device
