NetApp Knowledge Base
Data ONTAP 7-Mode
Data ONTAP 7-Mode
Other Resources
Here is some sample text for the Resolution Guides tab.
  • How to identify a failed disk prior to replacement in Data ONTAP 8.2.5 7-modeFri, 11 Oct 2024
  • Data ONTAP 8 - Spare disks for zoned and advanced_zoned checksumThu, 08 Aug 2024
  • 7-Mode: How to get a list of cifs shares without access to the ETC$ shareSat, 20 Jul 2024
  • The ongoing migration project on 7MTT goes missing after a power outageFri, 09 Feb 2024
  • Unable to mount NFS export using kerberos and getting permission denied errorWed, 13 Dec 2023
  • 7 mode node showing cmd_system: exec_status=5 errorMon, 11 Dec 2023
  • 7MTT - Transition start failed - Error: Unable to set volume attributes for volumeWed, 25 Oct 2023
  • 7-Mode: SyncMirror Plex FailedThu, 19 Oct 2023
  • 7MTT prechecks fail with error 75002 due to local user exceeding the max limitSun, 10 Sep 2023
  • Baseline copy fails as 7-mode storage system is not reachableMon, 21 Aug 2023
  • Disk showing 'init failed' after replacement on ONTAP 7-mode systemThu, 17 Aug 2023
  • WORM files have 0 retention after migration from 7-modeThu, 20 Jul 2023
  • Repeated node panics due to SnapMirror relationships from a 7-mode systemSun, 16 Jul 2023
  • After migration from 7-mode to Ontap 9 permissions getting changed on CIFS pathFri, 26 May 2023
  • Unable to Mount on 7mode system after Node failoverMon, 22 May 2023
  • Does 7 MTT require rebaselining after a physical relocation of 7-mode or C-mode systems?Sat, 20 May 2023
  • Unable to create volume clone due to license DB being unavailableMon, 08 May 2023
  • Is there risk if language setting is changed for an existing 7-mode volume?Thu, 20 Apr 2023
  • Is there patch planned for CVE-2022-38023 on 7-mode?Thu, 20 Apr 2023
  • 7MTT transfer fails due to TDP destination volume on the clusterMon, 17 Apr 2023
  • How to perform a system health check with Autosupport or Active IQ onlySun, 08 Feb 2026
  • Quota resize returns message skipping new definitionFri, 09 Jan 2026
  • What happens when a disk fails and does not have a hot spare installed?Tue, 06 Jan 2026
  • Deleted snapshot does not release space in volume/aggregateFri, 12 Dec 2025
  • How to control the SMB 2.1 feature in Data ONTAP 8.2.3 operating in 7-ModeMon, 17 Nov 2025
  • How to perform MetroCluster failover method for a planned site-wide maintenance not requiring CFODTue, 04 Nov 2025
  • How to get to the LOADER prompt from Data ONTAP 8 7-modeWed, 17 Sep 2025
  • How to reset root password from boot menu ONTAP 7-ModeMon, 21 Jul 2025
  • What are the common causes of CIFS SETUP failures?Mon, 23 Jun 2025
  • Error message: Permanent errors on all HA mailbox disks (while writing master block) in process fmmbx_instanceThu, 12 Jun 2025
  • When a directory or file is dragged / dropped or moved, why are the access rights not inherited?Mon, 09 Jun 2025
  • How to Netboot clustered Data ONTAP 8.1x (and later)Fri, 25 Apr 2025
  • How to upload a Data ONTAP 7-Mode core file for analysisFri, 25 Apr 2025
  • How to view snapshots and determine the size of snapshots in 7-ModeFri, 25 Apr 2025
  • How to grant and remove access to CIFS sharesFri, 25 Apr 2025
  • How to recover a deleted file from a snapshot using Network File System (NFS) or Common Internet File System protocol (CIFS)Wed, 09 Apr 2025
  • How to add users to the BUILTIN\ADMINISTRATORS group for a storage systemFri, 04 Apr 2025
  • Is ONTAP 9.12 supported as a target for migration with the 7MTT?Wed, 12 Mar 2025
  • Disks are not owned or report a Bad label after running the disk sanitize release commandTue, 04 Mar 2025
  • Aggregates are in a double degraded or double reconstruct stateThu, 06 Feb 2025
Add code for Video content
