NetApp Knowledge Base
command failed: Unable to set volume attribute "files" for volume in ONTAP
774
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • Inode count
Issue
Below error message can be found when trying to change the Inode number to a specific number.
Example:
cluster::> df -i
Filesystem      iused   ifree    %iused    Mounted on     Vserver
/vol/Share01/   2027    21249099 0%        /Share01       svm_01
cluster::> vol show
Vserver   Volume       Aggregate    State      Type Size       Available  Used%
svm_01    Share01      aggr1        online     RW   100GB      94.85GB    0%
cluster::> vol modify -volume Share01 -files 42502252
Error: command failed: Unable to set volume attribute "files" for volume "Share01" on Vserver "svm_01".
Reason: The value you entered(42502252) is invalid; maximum inode count cannot exceed 24903679.
Cannot support more than one inode per 4 KB of disk space.
New to NetApp?
Scan to view the article on your device
