NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
NetApp Knowledge Base
Why "volume show" shows a value greater than 0 for "Space Saved by Deduplication" even if volume efficiency policy is not set ?
280
Visibility:
Votes:
0
Category:
data-ontap-8
Specialty:
core
Last Updated:
Applies to
ONTAP 9
Answer
This is expected behavior when using ODX for copy offload on storage virtual machine (SVM) , because ODX uses deduplication as part of copy process.
In this case, "volume efficiency show" command shows volume efficiency policy is disabled.
Example:
::> volume efficiency show
Vserver    Volume           State     Status      Progress           Policy
SVM_name   Volume_name      Idle      Idle for 1049:24:04 -        Disabled
However, "volume show" output shows value grater than 0kb at "Space Saved by Deduplication".
Example:
::> volume show -volume vol1
                                     Vserver Name: SVM1
                                      Volume Name: vol1
        Volume Contains Shared or Compressed Data: true
                Space Saved by Storage Efficiency: 768KB
           Percentage Saved by Storage Efficiency: 0%
                     Space Saved by Deduplication: 768KB
Additional Information
Add your text here.
Scan to view the article on your device
